67 Seat Belt retractor - NCRS Discussion Boards
  • john daly
    My 67 convertible seat belt on the passenger side is stuck in the extended position. It no longer retracts the belt. What could this be a broken spring? Are parts available for this ?
    thanks in advance
    john
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: 67 Seat Belt retractor
    Pull it apart and take a look. Possibly just stuck in the extended position.
    To remove the plastic cover just heat it a little in the sun or with a hair dryer and then slide it off the seatbelt retractor assy. That exposes the spring in a plastic container. Pop the top and see if its broken.
    Write me an e-mail if you want a photo of the breakdown of parts
      PS...
      when you find and correct the problem, wind the retaining arm 8 full revolutions to properly cock the spring for full retraction of the belt before you re-install the retractor....
      • J B.
        • May 31, 2005
        • 26
        John,
        If you find that the problem is that your retractor springs are broken read on.
        I have a very early 68 with retractors that are very similar if not exactly like the 67's. Both sides of mine had the spings broken.
        I found a junkyard with a pile of 60's GM cars and the springs on almost every stlye of retractor were duplicates. I looked until I found a couple of dry interiors and salvaged 4 good springs.
        If you can't find them in your area send me an email and I will send you one of my spares.
        Jack
