1965 396 Fan Shroud GM Part Number...Joe??? - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2660
    Is the correct GM part number for a 1965 396/425 fan shroud GM #3938940?
    Any help would be greatly appreciated.
    James West
  • William C.
    • May 31, 1975
    • 6037
    Re: 1965 396 Fan Shroud GM Part Number...Joe???
    Two pieces James, 3872995 and 996. 3938940 was '68 427.
    Bill Clupper #618
    • James W.
      • December 1, 1990
      • 2660
      Re: Thanks Bill! *NM*
        • 43232
        James------
        The numbers are as Bill described. Some references may indicate that the 3938940 shroud will SERVICE the 1965 L-78 application. It won't, though. As Bill mentioned, the 3938940 is a 1968 issued shroud. It is SERVICE-only for 1968 with copper/brass radiators (some small block and all big block except L-88) since the actual PRODUCTION shroud was made up from several individual pieces (which, together, make up the 3938940 SERVICE shroud). The 3938940 is also SERVICE for 1966-67 big block applications. However, it won't work for 1965 L-78 applications. That's because 1965 L-78 used a different radiator than that designed for use with the 3938940 shroud.
