7040207. whats this valve? - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    Saw this on ebay.original with the "deceleration valve", as he calls it. My L-46, 4 speed doesn't have it. Anyone?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 7040207. whats this valve?
    on the throttle linkage side of the carb instead of a simple idle speed adjustment screw it has a idle speed adjustment with a built in dashpotto allow the throttle to close slowly so not to stall the engine.i would guess it would only be on auto trans equipted cars you can see it in the picture
    • Dennis D.
      • March 1, 2000
      • 1071
      auto trans would be my guess too. The 7040207 is a 4 speed carb though. Thanks
      • Clem Z.
        • January 1, 2006
        • 9427
        i have seen this item on truck carbs also
        • Mark #28455
          I also have one on my 1970 LS5 454 w/ 4speed
          • Richard W.
            • May 31, 1988
            • 58
            I also have one on my 1970 LS5 4-speed w/AC.
            That is a good looking carb for sale.
            Rick Weltzin
            • Dennis D.
              • March 1, 2000
              • 1071
              Are your big blocks early cars?
              • Clem Z.
                • January 1, 2006
                • 9427
                does your corvette have A/C? if it does that could be the connection
                • Richard W.
                  • May 31, 1988
                  • 58
                  Mine is a rather late build. June 1970.
                  LS5, 4-speed, AC. It has the valve.
                  Rick Weltzin
                  • Dennis D.
                    • March 1, 2000
                    • 1071
                    Clem
                    No AC for me.( no valve either). I think that carb number would be correct for an L-46, 4 speed with air as well. Have to check your theory with L-46 cars.
                    • Mark #28455
                      March 1970 454 4 speed with A/C.
                      • Tony H.
                        • May 31, 1993
                        • 537
                        Dennis,
                        My 1970 454 with 4-speed and NO a/c is a late July-built car and it has the same accelerator idle part.
                        Tony
                          • 43221
                          Dennis-----
                          The part in question is a combination idle speed screw and "idle control valve". The purpose of it is to slightly delay the return of the engine to the idle condition and it is an emissions control part. It was used on SOME Rochester Q-Jet carbs in the 70-74 period. Some Holley carbs also used a similar device, although the configuration and functional design were somewhat different.
                          Once-upon-a-time, I researched the part numbers of these pieces. I found the ones used for the Holley carb applications. However, I suffered a "major defeat" with the Q-Jet piece----I was never able to come up with a part number for it.
                          • Dennis D.
                            • March 1, 2000
                            • 1071
                            Joe
                            congrats and welcome back.
                            Would you say the piece is a california part, if found on a 70 L-46? Haven't had any responses from 70 L-46 owners. Does it fit into the carb the same way as the idle screw, or is there a different carb base for it?
                              • 15601
