Radiator replacement on 1969 Corv 427/435 - NCRS Discussion Boards
  • Larry Williams
    i own a 1969 427/435 tri-power automatic coupe,with 46k. i would like to replace the radiator, i'm unsure if it has the original radiator. rather than make a costly purchase mistake, i'd appreciate your help in sending a photo of an original radiator and do you think ecklers has one. i'm planning on showing the car this summer.
    • 43222
    Re: Radiator replacement on 1969 Corv 427/435
    Larry-----
    Your car should be equipped with a Harrison brass radiator of GM part number 3019190. This radiator utilizes an external supply tank and has NO radiator filler cap. It has a core which is 27-1/2" wide. It has two fittings at the lower, rear for the transmission oil cooler which, for your M-40 equipped car, will be seen with the transmission oil cooler lines attached. The radiator MAY display the part number I mentioned on an attached metal tag. In any event, it should have the Harrison sylized name embossed on it. If so, and it's otherwise of the configuration which I described, it's probably the original one or a correct replacement.
    The GM #3019190 radiator is discontinued and replaced by GM #52481556. This radiator GM lists for $671.11. I don't know what, if any, differences that this replacement exhibits with respect to the original.
