C2 intake_ torque wrench access ?? - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    '63, 327-340, intake manifold P/N 3844461.
    Because of the configuration of the manifold, I can't fit a socket and torque wrench on the 4 center bolts and one of the end bolts by the thermostat mount. How do I properly torque these bolts?
    Steve
  • Ralph E.
    • February 1, 2002
    • 905
    Re: C2 intake_ torque wrench access ??
    Without the Carb in place!
    • Steve D.
      • February 1, 2002
      • 990
      Carburetor is not installed yet
      I am reassembling the engine, and the Carburetor is still on the shelf.
      Steve
      • Ralph E.
        • February 1, 2002
        • 905
        Re: Carburetor is not installed yet
        Are you sure it is all four bolts? One bolts on each side uaually needs a thin wall socket. You may need to grind down an old socket to make one that will work.
        • Steve D.
          • February 1, 2002
          • 990
          I can get the socket on the bolts, but I can't get the rachet or torque wrench on the socket; the angle is wrong. Also, the oil fill tube prevents getting on one of the end bolts also.
          Steve
            • 11652
            I use a universal joint, or a universal joint socket. While your torque value will change slightly, I've never found a better way.
            Patrick
            • `Michael Southard
              Use a crows foot, and take off a half a foot lb.
              • Craig S.
                • June 30, 1997
                • 2471
                I use the crow foot method too.....works well....Craig
                • Werner R.
                  • March 3, 2008
                  • 184
                  well, i'll bite. what is a crow's foot??
                    I just use a box-end wrench, pull manually with the same effort it takes to move one of the other bolts that's already torqued with the torque wrench.
                      • 15696
                      A crow foot is an open end "socket" with a square drive to attach to conventional socket drives. It got the name from its shape. The are available as open end, "tubing wrench" (five sides open on the sixth) and I think box end.
                      There's also a tool called a "wobbly extension" that allows a socket some freedom of drive angle if you don't have a straight shot to the bolt head, so they are great for those tough to reach bolts.
                      John's method also works just fine.
