C-1 Changing Tail light Lens - NCRS Discussion Boards
  • Robert S.
    • July 31, 2004
    • 377
    Hi all! I have a new rear tail light lens and I'm trying to replace just
    lens on my '54. I have the tail light housing out but I am unsure how to
    separate the lens from the housing. Has anyone ever changed out a tail light
    lens on a 53-55? What's the secret to removing the lens and bezel from the
    bulb housing? Thanks in advance for any help you may offer.
    Bob
    Bob
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C-1 Changing Tail light Lens
    You need to brake the lens to get it out ,then glue the new one in.
    • Robert S.
      • July 31, 2004
      • 377
      Thanks Roy, I was thinking of going that way but I figured I'd check with the experts like you first. Bob
      Bob
      • Chris S.
        • January 1, 2000
        • 1068
        Roy's right - break the old one - silicone the new in - make sure you orient the light correctly.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: C-1 Changing Tail light Lens BOB
          I still have the accessory 78 Silver Anniversary lugage when I got my new one in 78, but the vett is long gone.
          • Robert S.
            • July 31, 2004
            • 377
            Re: C-1 Changing Tail light Lens ROY
            Still got your 27 year old luggage!You're worse them at getting rid on old stuff
            Roy may be you need to get away more and use that luggage or are you just holding on to them for sentimental reason?
            Thanks again for the tip on replacing the lens. I broke out the old one which still had the rubber gasket in the base of the lens. I tried to reuse the gasket but the repo lens won't fit with in the housing, so I used some clear silicone sealer.
            Happy Motoring,
            Bob
            Bob
            • Roy B.
              • February 1, 1975
              • 7044
              We' v used the lugged for years and still do, I thought 78 owners would be interested in buying them for their vett , but NO .Accessories if your in to the NCRS mind set is a big bad thing never to be discussed.
