69-82 Front Spindles - NCRS Discussion Boards
  • Larry M.
    • January 1, 2002
    • 538
    I know there is a right and a left with the steering arms, caliper brackets and dust shields attached; but, with all this stuff removed, are the the right and the left spindle/knuckle the same...they look symetrical to me???
    • 43229
    Re: 69-82 Front Spindles
    Larry-----
    The left side and right side steering knuckles (spindles) are the same for all 1969-82 Corvettes. In other words, one part is used for both sides. The same situation is true for 63-68 Corvettes, too. The steering ARMs, which bolt to the knuckles, are side-specific as are the caliper brackets and dust shields.
    • Larry M.
      • January 1, 2002
      • 538
      Thanks a lot Joe...when you say it I take it to the bank.
      • Harold #43147
        Just to add to Joe's reply 63-68 had small Dia. Bearings 69-82 had large Dia. A lot of people do not know this but theses spindals will fit 65-70 Impala if some one wants to do a disc conversion.
