Lower steering column component finishes - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Would someone please be able to tell me what the proper finish is for
    :the cast coupler and it's bolt that connects the rag joint to the steering column shaft.
    :the "tie rod sleeve" clamp and it's bolt & nut that is located about 1/2" further up the steering column shaft from this cast coupler.
    :the little cup/cap that slips over the lower end of the steering column tube.
    :the spring/clip that holds this cup/cap onto the steering column tube.
    • 43240
    Re: Lower steering column component finishes
    Greg-----
    For 68-76, the components that you inquired about were all black/gray phosphate finished.
    • Harold #43147
      Color
      If you Zinc Plate the parts first and then use a Black Oxide dip it will duplicate Black Phosphate kind of has a little sparkle when the sun hits it
      • Greg L.
        • March 1, 2006
        • 2291
        Re: Color
        Thanks again guys.
