smoke - NCRS Discussion Boards
smoke
  • jim cochrane
    smoke
    I have a slight oil smoke problem with my 66 427/390 that I don't understand. I get a small puff of smoke only after the motor has been running for a while, and only when you stop at a ligh and then accelerate. The motor is a fresh complete rebuild and oil changes have been regular. Does this sound more like a ring problem, a valve seal problem, or could it be possible that infrequent use cuased the seals to dry out. Could pump gas in these 427's create an issue. And how can I test to isolate the issue. The motor runs great, it's just n annoyance. Any help would be appreciated.
    Jim Cochrane
    • 43219
    Re: smoke
    Jim-----
    How much oil does the engine use? In other words, how many miles do you get on a quart?
    • Erik S.
      • January 1, 2005
      • 407
      Re: smoke
      Jim - the guy who is going to rebuild my L71 engine said that you will start notice less oil consumption only after 4000 km / 2400 mls. You mention that the rebuild is fresh so maybe you should be a little more patient. Maybe others can confirm this.
      Erik
      Nederlandse club voor Corvette liefhebbers, met of zonder auto. Opgericht in 1993. Uitgebreid forum, meeting-agenda, fotoalbum en meer.
