Were the same FI Air Cleaners used from 58 - 62? *NM* - NCRS Discussion Boards
  • John Farwell
  • Mike M.
    • May 31, 1974
    • 8390
    Re: Were the same FI Air Cleaners used from 58 - 6
    basically the same except for the size of the stamped "X" on lid. see judging manuals for the two sizes. mike
    • Mike M.
      • May 31, 1974
      • 8390
      • Ed Jennings
        The 62 air cleaner is different. Aside from the smaller "X", the filter element is entirely different. I think the two assemblies (58-61,62) would interchange, but don't believe parts of one type would interchange with parts of the other.
        • Ed Jennings
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            I would describe...
            ...the base asy as being the same from 58 - 62. During '62, the cover changed to the smaller X. The changeover is described in the JM - somewhere in the 5K range if I remember correctly. The 58 - 61 filter element was a paper item - I would imagine the switch to the foam element on a screen may have mirrored the small x, big X change.
            • Dennis C.
              • January 1, 1984
              • 2409
              I would describe...
              • Mike E.
                • February 28, 1975
                • 5139
                Re: I would describe...
                Changeover to small x in 62 ENDED in the early 5000 range--began as early as 600, and probably even earlier than that.
                • Mike E.
                  • February 28, 1975
                  • 5139
