tachometer/mechanical to electric - NCRS Discussion Boards
  • Dr. Dennis M. Szal
    Is anyone aware of anything on the market that is a change over from a mechanical to an electric tachometer for a 1960? If so, is one brand better than another? and do you have any numbers on the part? We have to change distributors and we're thinking about going to an electric set up.
    thanks in advance
    • 43241
    Re: tachometer/mechanical to electric
    Dennis-----
    It depends what you're after in the "final product". If you're after a tachometer that will fit cleanly in the 1960 dash opening and look just like the original tachometer but operate electronically, then I don't know of any such "animal". Certainly, there is nothing available from GM now (or, as far as I know, EVER) to accomplish this. Whether there is an aftermarket unit like this, I don't know.
    If you just want to install an electronic tachometer and are not concerned about the above-referenced issues, then it's easy. An electronic tach can be retrofitted to the car very easily. It's an easy 2 wire hook-up and you're ready to go.
      • 43241
      Dennis-----
      • Wayne P.
        • August 31, 1975
        • 1025
        If you have an original 60 the tach should be off the generator not the distributor, unless it's a high horse FI.
        • Wayne P.
          • August 31, 1975
          • 1025
          • Dennis Rosenthal
            Corvette clocks by roger will sell you a factory looking tach with elec internals. I have used several without any problems.
            Dennis
            • Dennis Rosenthal
              Dennis
