66 cluster wiring harness hazard? - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    I have just removed the cluster on my 66.
    In order to test my intended wiring repairs and test bulbs before installation to cluster, I'd like to power up the harness as it hangs there. Switch key to acc, pull light switch on and test bulbs in sockets (with ground jumper wire) as they hang in the harness. Is this dangerous and may cause a fire or am I protected by the fuse block?
    yes I'll test the bulbs before insertion into the socket too but I also expect some bulb not properly seated issues too.
    Randy aka "sparky".
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 66 cluster wiring harness hazard?
    Dear Sparky,
    Adequate protection should be afforded by a large dry chemical fire extinguisher that can be purchased at most hardware stores.
    Other than that-there ain't no guarantees!
    JR
    • Brian M.
      • February 1, 1997
      • 1840
      That dry chemical fire extinguisher will do more damage that the fire. JMHO.
      • Randy S.
        • January 1, 2003
        • 586
        J Ray and Brian
        So I take it you wouldn't try this. Just bench test the bulbs and test again before cluster is buttoned up for good.
        Randy
        • Brian M.
          • February 1, 1997
          • 1840
          Replace all the LAMPS with quality USA made LAMPS and you'll be good to go.
