Protecting the engine numbers - NCRS Discussion Boards
  • Jim Baxter
    What can I put on the stamped engine block numbers to protect them from rust?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Paint or Grease might work... *NM*
    • Eugene B.
      • May 31, 1988
      • 710
      Re: Protecting the engine numbers
      Jim,
      A couple of thoughts on your question.
      To keep natural surfaces from rusting, I like a product called PreLube 6 from Quanta. Comes in a spray can.
      Thought two. When changing engine oil, one could take a dipped finger of clean motor oil and apply it to the stamp pad. Assuming that you change oil at regular intervals, no rust should occur.
      Gene
      • Timothy B.
        • January 1, 2004
        • 438
        Also, you can grind off the pad so that there is good tooth for paint and paint the pad with rust preventative paint. Make sure you get rid of those pesky numbers that interfere with a good smooth finish.... :-)
          • 15696
          Armor-All or WD-40.
          • Donald W.
            • August 12, 2013
            • 190
            Jim,
            I used a spray can product from L I Corvette supply made for protecting natural metal finishes
            • Robert C.
              • December 1, 1993
              • 1153
              Re: Vasaline *NM*
