'66 BB INNER FENDER MOUNTING HOLES - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Did original inner fenders on big blocks have any of the holes drilled out for small block applications,(overflow tank, etc.) or were they just indented to show their position?
  • Mike M.
    • May 31, 1974
    • 8390
    Re: '66 BB INNER FENDER MOUNTING HOLES
    mine indented. mike
    • Michael H.
      • January 29, 2008
      • 7477
      Rob,
      The holes in my 66 were drilled but the factory undercoating from the back side makes two of them look indented, not drilled. The other two have factory undercoating oozing out on the back side.
        The holes in the RH inner fender for the expansion tank bracket rivets were pre-drilled 100% in all panels by the supplier, and those holes were filled with bond material on BB cars.
        • Mike M.
          • May 31, 1974
          • 8390
          both of my 66's with no holes are big blocks, one ao smith, other st louis. will have a closer look at the skirts and look for the bondo fill. thanks for enlightment, john and mike. mikie
          • Bill Stephenson
            -------John is, as usual,.....correct..........Bill S
            • Ted K.
              • August 31, 1994
              • 337
              My 66 big block, a correct car, has four holes drilled in right fender for small block expansion tank. I've wondered what they were for many times. Sounds like all 66's came with them.
              • Michael H.
                • January 29, 2008
                • 7477
                Yes, john is correct. I looked at the 66 again and the goonk that's ozing out from two of the four holes is definitely bond, not undercoat. If I look at that area from the wheel side, I can see where bond was spread in the area of the holes and then covered with factory undercoat.
