ALL KINDS of C-2 NUMBERS??? - NCRS Discussion Boards
  • `Michael Southard
    I think I have ascertianed that I have the appropriate trany for my SWC. With my VIN being; 30837S116445. My Trans numbers are 3116445 located (stamped) on the driver side rear flange with about 1/4" numbers.
    The casting # on the trany side plate is 3831704.
    The casting # on the tail housing is 3831731.
    I can't make heads or tails of the differential. Passenger side # is 3899148-N and on the driver side what looks to be "J 76" ??? Nolan Adams book seems to be a little vague in this area. Well it doesn't show my numbers anyway.
    Is there a website out there that can easily track down casting #'s for any chev. block. My 350 4-bolt cast # is 8970010. Then on the right side (smaller figures) is 8233.
    Thanks, Mike S.
  • Joe R.
    • July 31, 1976
    • 4551
    Re: ALL KINDS of C-2 NUMBERS???
    Michael,
    Looks like the block should be # 3970010 and could have came in a 70-72 Corvette or most likely a truck. Got my 010 block from my 1974 Blazer.
    JR
    • `Michael Southard
      JR,
      It is possible the number is a 3 rather than an 8, It is a little obscure.
      Thanks Mike S.
      • Jim T.
        • March 1, 1993
        • 5351
        Michael,
        Corvettes from 1969-1980 used the 350 cu in block 3970010.
        • Kevin Whiteley
          Mike,
          3831704: Muncie 4-sp. main case for 63 Passenger and Corvette.
          3831731: Muncie 4-sp. tailhousing for 63 Passenger and Corvette.
          Looks like the above two were for 63 only, as the #'s changed in 64.
          3899143: 67-69 Axle Center section.
          My book doesn't show an "N" and the last digit is probably a "3" rather than an "8". "J 7 6" is October 7, 1966 which matchs for the 67 model year. Look for a stamped code on the bottom of the carrier. It will tell original axle ratio, date of assembly, and shift code.
          3970010: "8223" probably is August 22, 1973. This block was used until 75.
          I don't know of a good website, but Colvin's books are a good reference.
          • `Michael Southard
            Great, Thanks Kevin.
            Where did you find this information?
            Mike S.
            • William C.
              • May 31, 1975
              • 6037
              Mortec.com is a good site for chevy engines and heads. I wrote an article on the '63 Muncie for the restorer about 10 years or so ago, if you have the Cd, there is a wealth of information there.
              Bill Clupper #618
              • `Michael Southard
                Bill,
                Are you refering to the CD that NCRS offers? Do you know if the info on the CD also covers the same stuff as the "63-64 NCRS Tech & Judging Guide"?
                I'm just trying to keep from purchasing redundancy.
                Mike S.
                  Mike -
                  The CD is a compilation of all the articles that have appeared in the "Restorer" magazine from day one, and is an extremely useful reference - well worth its cost. It's not the same as the TMI&JG.
                  • `Michael Southard
                    Thanks John, Consider it ordered!
