67 Steering column lower mast jacket - NCRS Discussion Boards
  • Donald W.
    • August 12, 2013
    • 190
    Could someone tell me about the steering mast jacket area under the dash, whether there is a covering over the expansion metal section of the column. My 67 is an early production date Nov 1,66 build and there is no covering. If there is a covering that should surround the lower mast jacket area, than what type of material is it and possibly a supplier that i could purchase it from.
    Re: 67 Steering column lower mast jacket
    My '67 is a later car, and has that section fully covered with a black plastic sleeve that's tapered at both ends.
    • Justin N.
      • February 1, 2004
      • 318
      Don,
      My '67 coupe built Dec. 19th, 1966 has the same black plastic covering that John speaks about. It covers the 'webbed' metal, lower column and has small tabs that were heat-melted to hold the covering together. I haven't seen it listed anywhere. You might call Dave Sokolowski at (310)329-5334 in the Southern Los Angeles area. His sarcastic personality is a bit off, but he's got more used parts then anyone I know.
      Justin #41362
      • Brian M.
        • February 1, 1997
        • 1840
        My Jan. built car has the same cover.
        • Jon #40768
          My October 66 car has it to. there is also a metal wiring cover. The wiring cover and I think the plastic covers are available at LI corvettes.
          Jon
