C-1 59 Help Needed - NCRS Discussion Boards
C-1 59 Help Needed
+ More Options
Posts
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 59 Help Needed
    Still need someone to give me mesurement on pass. side hood release cable for 59 with early stye latches, where it exits from the firewall. PLEASE PLEASE Thanks
  • Al C.
    • July 31, 1999
    • 274
    Re: C-1 59 Help Needed
    Jerry - On my '58, both hood latch cables come thru the firewall at one grommet, below and just outboard of the master cylinder. There was a thread some months back about this, I think it may have changed in later years. Here's my photo link:
    ... Al '58 245hp
    • Pat #25912
      Al, that is how they exit the firewall on my Jan '59 car (one hole) but I don't believe it is correct. According to the '58 AIM (supposedly the same for early '59) the driver's side exits as shown in your pic, but the pass side exits a little more inboard and a little lower. Almost in the center of the firewall (behind the distributer) there should be a clip. About 6 or 8" to the driver's side of the clip, just as the indented part of the firewall curves around, you should find the cable exit hole. It is there on my car and I plan to correct that when I pull the motor this winter. Oh...and that clip...it supports the release cable. If you or Jerry would like a fax copy of the aim, send me your fax number. I asked this same question about a year ago and a forum member faxed the page to me.
      • Al C.
        • July 31, 1999
        • 274
        Pat - I'm emailing you a copy of a thread on the board from 3 years ago, that I also had emailed to Jerry. There were several differing opinions; at least for '58, I decided to stick with the "both in one grommet" approach. I think my '58 AIM sheet is dated much olater than my car (Oct. 57). Regards, ... Al '58 245hp
