C3 1968 427 Block - Dipstick Tube Leak - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2135
    I found a leaking dipstick tube, so I took an o-ring from an assortment, slid it up to the "shoulder" and re-installed the tube. Now not as bad, but still squirts oil out.
    I've seen a drawing that indicates the o-ring should be a "seal", but the guy (the experienced owner) at the parts store says he's never seen or used one.
    What would fix this problem? Thanks
    Tom D.
    Remember to get out to Woodward today!
    MichiganNCRS.org
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • 43232
    Re: C3 1968 427 Block - Dipstick Tube Leak
    Tom------
    Assuming that neither the dipstick tube nor the tube in the pan are significantly distorted, I would recommend that you use the special seal designed for this application. You can obtain one at your GM dealer under GM #274244. That's also exactly the same seal that was used for your application when it was originally installed at St. Louis.
    • Tom D.
      • 2135
      Thanks Joe *NM*
      Michigan Chapter
      Tom Dingman
