'66 Fan shroud paint question - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hi,
    When were the fan shrouds installed at the factory? I have an original that has factory primer overspray under the black that has worn off and I was wondering what the steps were for installation and painting.
    Ian
  • Michael H.
    • January 29, 2008
    • 7477
    Re: '66 Fan shroud paint question
    Ian,
    The fan shroud was in a totally different area of the assembly plant when your Corvette body was primed/painted so there should be no primer or body color on it. The shroud was painted black prior to installation.
    • Mike M.
      • May 31, 1974
      • 8379
      agree with mike. oftertimes one will find broadcast labels under the black paint. underneath the labels is raw glass. mike
      • Dave K.
        • November 1, 1999
        • 952
        Sprayed mine with GM Restoration black. Any not too shiny semi gloss will work. Installed the shroud before I dropped the body back on to the frame.
        Dave Kitch
        • Ian S.
          • June 30, 2002
          • 264
          Thank you *NM*
