Battery Storage Compartment Gasket - NCRS Discussion Boards
  • Bill#34162
    The gasket is missing so although the compartment door latches, it rattles. I purchased the gasket. It is a dense foam about 1/4 inch thick. I need to know if it is correct to use an adhesive on the bottom of the gasket or does it just dry fit in place? Thanks.
    • 43240
    Re: Battery Storage Compartment Gasket
    Bill-----
    On my 69 the gasket is attached with adhesive. I'm fairly certain that 70 would be the same.
    • John Moore
      I just replaced the original gasket on my 71. It was held in place with adhesive. I did the same on replacement.
      John
      • Gary S.
        • July 31, 1992
        • 1632
        My original and unrestored 72 has a gasket that is glued on. Gary
        • Bill#34162
          Re: Suggestions on Adhesive
          Do you think a spray type would work or something more like a thicker, caulk type. Thanks for the replys.
          • John Moore
            I guess you could use a spray if you mask off the frame to prevent overspray. I used weatherstrip adhesive. Got it at PepBoys for about $5 for a small tube. Applied with a Qtip to both surfaces and installed gasket.
            John
            • Bill#34162
              Re: Thanks *NM*
              • Reba 8804
                Be sure to get the straight piece of foam that is formed around the compartment frame. Some repros are die cut, pre-formed to the compartment shape in one continuous piece. The originals had a definite end.
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Bill on my original owner 70 the gasket is glued.
