Grounding Wire ??? 1961 - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I have one last wire to connect on my 1961 and if everything is correct the electrical connections will be done. The problem is that I am not sure where this ground wire (???) connects. It seems to be a 12 GA black wire that I assume is a ground. It is approximately 3' long with two eyelets terminals. The wire travels from under the dash passenger side through the rubber grommet on the passenger or right side with the harness (not part of the harness). My best guess is that it metal dash support ground.
    Again, Thanks for all the help!!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Mike E.
    • February 28, 1975
    • 5139
    Re: Grounding Wire ??? 1961
    side radio mount bracket to valve cover. Check the AIM under the radio section--it should show that, as I recall.
    • Mike E.
      • February 28, 1975
      • 5139
      • Ray C.
        • June 30, 2001
        • 1132
        Thanks!!!! Mike
        I would have never thought of that, just finished tightening up the bolt and valve cover screw with the grounding wire.
        Again, Thanks
        Ray #36314
        Ray Carney
        • Ray C.
          • June 30, 2001
          • 1132
          Thanks!!!! Mike
          Again, Thanks
          Ray #36314
          Ray Carney
