Cut-out on bottom -right of fan shroud - NCRS Discussion Boards
    Re: Crude indeed
    That indentation has smooth molded edges and rounded corners on my '67 (and on other original 67's I've seen).
      Re: Crude indeed
      • Chuck S.
        • April 1, 1992
        • 4668
        #18
        Re: Crude indeed
        Gary, check your AIM in "Front End Sheet Metal" section (UPC11/13 for 70) for instructions of such a cut on appropriate pages dealing with front end fiberglass. On C3s, several such cuts were made on the body, but not without clear direction. I'll bet the cut is documented somewhere in the 66 AIM.
        Firewall cut-outs are an obvious example, but on C3s there is also an area on right front fender vertical flange inside the wiper compartment that was roughly hand cut. In spite of detailed instruction, these cuts are typically not identical (UPC11/13, SheetA2).
        • Chuck S.
          • April 1, 1992
          • 4668
          #19
          Re: Crude indeed
          • Gary B.
            • February 1, 1997
            • 7034
            #20
            Good suggestion; I'll check the 66 AIM *NM*
            • Gary B.
              • February 1, 1997
              • 7034
              #21
              • Wayne W.
                • April 30, 1982
                • 3605
                #22
                Re: Good suggestion; I'll check the 66 AIM
                The knotches in the lower valence panel is not rough cut, but has moulded edges on it. Sometimes there is a little flashing there which looks rough. As for what it is for, Who Knows? There is no logical reason that I can think of. It is there on both BB and SB cars.
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  #23
                  • Ian S.
                    • June 30, 2002
                    • 264
                    #24
                    Anyone have a photo of this they could post *NM*
                    • Ian S.
                      • June 30, 2002
                      • 264
                      #25
                      • Robert C.
                        • December 1, 1993
                        • 1153
                        #26
                        Re: You got the spot, but what's it for? *NM*
                        • Robert C.
                          • December 1, 1993
                          • 1153
                          #27
                          • Gary B.
                            • February 1, 1997
                            • 7034
                            #28
                            Chuck; it's not in the AIM
                            Well, it's going to take a better man than I to find it in the AIM. I don't think it's there.
                            Gary
                            • Gary B.
                              • February 1, 1997
                              • 7034
                              #29
                              Gary
                              • Gary B.
                                • February 1, 1997
                                • 7034
                                #30
                                Ian, I've got a photo...
                                but I can't figure out how to post it.
                                Gary
