Mid-year heater hose question - NCRS Discussion Boards
  • Gary Schisler
    mid year heater hose question gary schisler this should be an easy question for the mid year experts out there i am putting in new heater hoses tomorrow and for the life of me i cannot find out which is the and which is the hose i am reasonably certain that the hose that comes off of the front of the intake manifold and goes to the lower heater core connection is the one that makes the one off of the water pump to the upper heater connection the am i right on this one also anyone care to look at their hose going to the overflow canister and tell me the length of the hose from the t to the canister thanks i am replacing the ugly orange heater hoses with some new ones i picked up at carlisle thanks as always gary
    • 43259
    Re: Mid-year heater hose question
    re mid year heater hose question joe lucia gary my recollection is that the hose goes to the fitting on the intake manifold and the to the fitting on the water pump actually it is not too difficult to confirm this as the nipples on the fittings are of different size to accomodate the different size hoses this is also true of the nipples on the heater core itself the expansion tank lower nipples are just one size since the same size hose goes in and out and if i recall correctly this is the
    • Gary
      re mid year heater hose question gary thank for the replies as it turned out i was bass ackwards on the hoses as you two said leave it to the general to do somethhing like that maybe year old logic might have said that they needed two different size hoses oh well it help keep the hobby and the suppliers in business all is finished and it looks a lot better there was very little info in the judging manual noland adams book or the assembly manual several catalogs had good pictures that helped thanks again gary
      • Carl R.
        • March 1, 1998
        • 166
        re mid year heater hose question carl rose hi mr schisler mr lucia is correct the two hoses are different sizes and the small goes to the intake manifold what year is your car some more heater trivia for you from my experience depending on who you read the cars had only one heater hose stamped with the gm marking 'can't remember if it is the hose that is unmarked there is also longitudinal ribbing in apparently at least five different configurations originally heater hose t is unpainted cad plated both heater hose fitings are also cad plated not painted with pump intake teflon tape is no no the hoses are held together by two black plated c like clamps probably it is inconsequential but the adams book has a picture of a car to determine which direction they should face the heater core itself is brass with a silver aluminum like paint over the outlet spouts the engine compartment box cover is unpainted and on some cars there is sealer along the upper and medial sides applied to fix leaks did you ask about all this good luck carl
