C1 Rear Cross Member Rivets - NCRS Discussion Boards
  • Rodney R.
    Infrequent User
    • December 1, 2001
    • 22
    I am replacing the rear crossmember on my 1960. What tool or method is used to crimp the rivets to fasten the crossmember to the frame? Thanks for your help.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C1 Rear Cross Member Rivets
    dolly the3 rivet head then peen the rivet tail with a ball peen hammer. mike
    • Roy B.
      • February 1, 1975
      • 7044
      If you use a hand torch to get them red hot first , then holding a bar of heavy steel on the heads, then using a wibbit gun at the bottom using a flat wibbit chuck works great for me.
      • mikemccagh
        Roy: is a "wibbit gun" a first cousin to a "wabbit gun"? elmer fudd.
