1963 Shifter - NCRS Discussion Boards
1963 Shifter
    • 43242
    Re: 1963 Shifter
    Ray-----
    GM says that only one shifter assembly was used for 1963s with 4 speed, regardless of whether T-10 or Muncie-equipped. That shifter assembly was GM #3824815 and it was a unique-to-1963 piece.
    I believe that the 1-2 and 3-4 shifter rods were the same for both transmissions, too. However, the reverse rod and all three shifter levers were specific to T-10 or Muncie.
    • Tom D.
      • September 30, 1981
      • 2136
      Thanks - to both you and Wayne M. *NM*
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Ray C.
        • June 30, 2001
        • 1132
        #18
        Re: Thanks - to both you and Wayne M.
        Thanks to all!
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
        • Joe R.
          • July 31, 1976
          • 4551
          #19
          Re: 1963 Shifter
          Joe,
          You are absolutely correct as Jerry and I have posted above that the shifter for a 63 is the same for a T-10 or a Muncie. It was changed in 63 because of the crossmember.
          Also, the 421 bellhousing was used for both T-10 and Muncie transmissions. The 63 Muncie had an aluminum 3 speed bearing retainer. The bellhousing did not change until 64.
          I've owned both T-10 (10,365) and Muncie (14,451) 63's with the 421 bellhousing on both.
          JR
