62 Rear Emblem Back Plate Paint Tips - NCRS Discussion Boards
  • Mike Harpster
    The rear emblem back plate on my 62 has an incorrect silver metal finish. I would appreciate any tips on how to paint (what paint) the back plate to look like the original black. I am planning on putting on a coat of primer followed Satin Black Rust-oleum #7777.
    Also, should some sort of a sealer be used between the back plate and the rear emblem? If so, what material is recommended.
    Mike
  • Mike E.
    • February 28, 1975
    • 5136
    Re: 62 Rear Emblem Back Plate Paint Tips
    Mike--
    Plate should be steel, not aluminum. You probably have a 58-61 backing plate which was aluminum. There is a gasket that fits between the emblem and the body (most suppliers sell that)--the backing plate butts up against the emblem with no gasket/sealer, etc., because the gasket between the emblem and the body keeps the moisture out.
    • William R.
      • February 1, 2001
      • 40
      Mike:
      My '62 backing plate is aluminum painted black & is original.
      • Mike E.
        • February 28, 1975
        • 5136
        Bill,
        How have you determinedthat it is original? Did you buy the car new?
        Thanks, Mike Ernst
