C1 '59: Tricks to remove glovebox molding - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12785
    Hi,
    I want my glovebox molding (and all the other stainless steel stuff) get polished but I can seem to get the upper and lower small glovebox moldings loose. The upper ones seem to the screwed from underneath the molding and the lower ones I can't get a spanner on the nuts due to the small room available.
    Are there any tricks to get these loose ?
    thanks,
    Rob.
    The C1 1959 Corvette Restoration Project
    Rob.
    NCRS Software Developer
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 '59: Tricks to remove glovebox molding
    Rob,
    They just snap on.
    Regards, John McGraw
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12785
      But how do I get them of ?
      Rob.
      • John M.
        • January 1, 1999
        • 1553
        Gently stick a flat blade screwdriver under one side and twist the blade and the trim should pop off. It just grabs the lip of the trim.
        • Dennis A.
          • April 30, 1999
          • 1010
          Rob...
          After polishing, have them chrome flashed, you will be glad you did...
