Carb Rebuildind - NCRS Discussion Boards
Carb Rebuildind
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 877
    Re: RE JERRY LUCK
    I had the same experience with my tri power carbs. Filled the float bowls and the engine fired right up. A slight idle ajustment and the carbs performed great for 5 years and 8,000 miles. I have since sold the car (last year) but the money I spent with Jerry was the best investment I made. He currently has 3 more carbs of mine. Good luck, Joe
    • Jack H.
      • August 31, 1999
      • 155
      Jerry Luck
      Several years ago I sent my 3721SB (Carter AFB) to Jerry for a rebuild. Both the primary jets screw slots were damaged and the primary metering rods were worn and one was bent. He kept the carb for almost three months before returning it. Recently I had occasion to remove the top and found the same damaged jets and rods in it. I guess all he did was clean it up and send it back. I won't use his services again!
        • September 30, 1999
        • 710
        Bob Kunz
        Did my Holley and it was excellent, car fired up no problems just a little idle ajustment. Turnaround was quick, he keeps in touch and lets you know what he is doing to your carb, and a fair price. At the time everyone was saying use Jerry Luck. I emailed him several times about sending him my carb, and asking a few questions about cost ect. No response from him at all. I would never use him for anything. He is slow and I guess he didn't need my business. Mike
        • Chris S.
          • January 1, 2000
          • 1068
          Re: Carb Rebuilding
          I have used Holley to do the tri power carbs on my Plymouth 440
          The quality was top notch - plating was perfect.
          Replaced all the hardware - very very nice
          I had Bob redo 3 of my side drafts - they are not running yet
          He was a little backed up - they look OK
          I had Daytona Auto in Florida do another set of side drafts - the turn around was much quicker, price was better, and they look much better
          Daytona Parts Co. A premier supplier of high quality carburetor repair kits and Ethanol resistant carburetor component parts for carburetors, from 1923 thru today
          Again I have not used either set yet, so dont know if there is
          tuning, or perf difference and not sure what set I am going to install.
