C2 universal joints - NCRS Discussion Boards
C2 universal joints
  • Steve D.
    • February 1, 2002
    • 990
    C2 universal joints
    Any advice on installing universal joints in the half-shafts? Special tools?
    I am installing the rear suspension on a bare frame. I have read the instructions in the shop manual, and I have a press, but the procedure is still not very clear.
    Steve
    Re: C2 universal joints
    Be VERY careful with the outboard U-joints (flange to drive spindle); that flange is easily distorted unless a spacer between its "ears" or bolt-on backing plate tool is used while pressing the joint; if you bend it, you'll need a new one. Other than that, it's pretty straightforward.
      • 43240
      Steve-----
      I don't recommend trying to install half shaft universal joints yourself. These are MUCH more difficult than drive shaft u-joints. I recommend traking them to a driveline shop for installation by a competent, experienced professional.
      If you decide to go ahead and do it yourself, then you MUST use a fixture to support the u-joint flange while removing and installing the u-joints. An old spindle flange, bolted and torqued, to the u-joint flange will work. But, as I say, you're going to find this a difficult and frustrating task if you do it yourself and you may not be satisfied with the results. Driveline shops do this service for a nominal charge.
      • Rob A.
        • December 1, 1991
        • 2126
        The "Spicer" brand u-joints (no grease fitting) will not fit in the flanges on the half-shafts. Precision brand will. Long Island insisted that the Spicer brand would fit but they didn't. My flanges are original, however, the Spicer joints would only fit replacement flanges. I had a shop in my area that does driveline and suspension install them, it was quick and inexpensive.
        • Ronnie Robertson # 36786
          I used Spicer's
          Permi-Lube's (no grease fitting) on my original 66.
          • Rob A.
            • December 1, 1991
            • 2126
            Re: I used Spicer's
            The shop that installed my Precision joints tried their Spicers and they wouldn't fit either. The body was too big, however, they fit in the other end.
            • Eugene B.
              • May 31, 1988
              • 710
              Re: I used Spicer's
              Gents,
              I used Spicer-life (no grease fitting) U-joints P/N 5-799X in my original '65 without problems.
              Gene
