Which end is up - NCRS Discussion Boards
Which end is up
  • John Thomas
    Which end is up
    I recently installed ACC carpet and backing in my 67 coupe. I installed the padding with the black rubberized (?) side up as I thought the original was. The carpet under the glass "bubbled". When I raised it to stretch it I discovered the black "rubberized" side of the pad had wrinkled. I called ACC and was informed the "rubberized" side goes down. Now I don't know which end is up.
  • Jack J.
    • July 31, 2000
    • 640
    Re: Which end is up
    John, I just checked the original carpet on my 64 coupe and the padding under the rear glass is with the rubberized side UP. Hope this helps.
    • Mike M.
      • May 31, 1974
      • 8379
      Re: Which end is up
      Rubberized side up on a 66 vette i did a couple years ago. mike
      • John R.
        • September 30, 1999
        • 288
        Re: Which end is up
        I replaced the original carpet in my 67 coupe two years ago. The rubberized side of the padding definitely goes up.
        • John Thomas
          Thanks all *NM*
