1963 Distributor Cap - NCRS Discussion Boards
  • Rick A.
    • July 31, 2002
    • 2147
    Got frustrated looking through the archives so thought I would ask - what is the Delco-Remy "short" tower distributor cap for 1963 "fuelies"? D308 or D310? My Corvette only parts catalogue doesn't list like this, but I seem to remember talk about both of these and want to be sure I buy the correct one if I find it!
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • 43240
    Re: 1963 Distributor Cap
    Rick-----
    The w/FI distributor cap is Delco D-310, also known as GM #1943047.
    • Rick A.
      • July 31, 2002
      • 2147
      thanks Joe! single brain cell phenomena set in again!
      Rick Aleshire
      • Irby G.
        • November 1, 2001
        • 267
        Hi Joe, Just curious if that is also the part number for the '63 340hp. Thanks.
          • 43240
          Irby----
          No, the 1963 340 hp did not use this distributor cap. The 1963 340 hp used a standard D-308 cap.
          • Rick A.
            • July 31, 2002
            • 2147
            Joe,
            Just trying to add to my knowledge base - so, the D308 was used on 340 hp and what other applications for 1963?
            D310 was used on the 360 hp fuelie - was this the only applicaton for 1963?
            Would assume so, since this is the "short tower" and is noticeably shorter by like 1/2 inch or so.
            Rick Aleshire
            • DANNY PANTUSO
              RICK, 63 CAP SHORT TOWERS ARE WHAT JOE SAYS,D310 FOR A FUELIE, IT WILL COST YOU ABOUT $300.00 FOR A NOS, I HAVE 2 IN A CAN. DANNY
              • Dave S.
                • August 31, 1992
                • 2926
                The difference in tower height between a D-310 and D-308 is 3/8".
                • Rick A.
                  • July 31, 2002
                  • 2147
                  Danny,
                  thanks for the response! like I said, it is nice to have someone who is going through the final stages of restoration of a Z06 as I get ready to start on mine I can see I will be posting alot hoping you will respond!
                  Rick Aleshire
                    • 43240
                    Rick-----
                    The D-308 was used for all 1963 Corvette applications, including fuel injection. I don't think that the "short tower" D-310 came into usage until sometime in the 1964 model year. Also, a VERY, VERY small number of 1963's with FI MAY have been built with a dual point distributor. IF any were actually produced, they would have used the D-324 dual window cap.
                      • 43240
                      Addendum
                      When I originally posted this information, I was speaking in more of a "generic" sense. The D-310, GM #1943047 was GENERALLY the distributor cap used for FI applications. However, since I posted this I did a little more research and, cross-checking from multiple GM sources, I cannot find any information which indicates that the D-310 was used for 1963 FI applications. It MAY have been so-utilized, but I can find no GM information which indicates that.
                      The first utilization of the D-310 which I can confirm, is the 1964 FI application.
                      • Tom P.
                        • April 1, 1980
                        • 1815
                        Re: Addendum
                        Obviously, the D-310 cap is no longer available, and expensive if you find an original or an NOS one. ALL of the caps which I have found to be available from the parts stores, are of the generic, tall tower variety------------one cap fits all. But, NAPA (Echlin RR168) has a SHORT tower cap available for 64-5 FI engines, which is an EXCELLENT replacement cap for 64-5 FI engines and it has brass terminals (not alum). Only one drawback, it doesn't have the Delco name or numbers on it. Too bad, it's a nice, short cap, and under $10!
