C1 60 Dash Pad - NCRS Discussion Boards
C1 60 Dash Pad
  • Terry B.
    • December 1, 1988
    • 111
    C1 60 Dash Pad
    Is it reasonably possible to install an instrument cluster into a NEW dash pad without removing some of the foam backing in the immediate area?
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C1 60 Dash Pad
    Never saw one you didn't have to carve a lot of foam out of before installing it on the dash. It's too late if you're ready for the cluster!
    • Mike M.
      • May 31, 1974
      • 8396
      Re: C1 60 Dash Pad
      wayne: you are correct in that dash pads available in the aftermarket arena(al knock, eckler etc) required a considerable amount of carving of foam in the past but i heard that the latest offering require little or no foam removal. guess it depends on when the pad was manufactured. mike
      • Joe Maulsby
        Re: C1 60 Dash Pad
        Trey, I installed a new al Knoch pad in my 1960 last November. The quantity of foam that needs to be removed is minimal on the new pads, but I still had to remove some so the cluster would fit as snug as it needed to; otherwise, the bolt holes may not line up. If you can get the vertical bolt holes to line up the way it is, you will be fine. The extra foam usually prevents the bolt holes from lining up.
        • Terry B.
          • December 1, 1988
          • 111
          Re: C1 60 Dash Pad
          Just finished the installation. It is just as Joe says.
