C3...Replacing door hinge spring - NCRS Discussion Boards
  • bruce11495
    I received a new spring this morning from UPS from MAD. There are no instructions on how to replace it.
    Does anyone have a simple method to doing this? I played with it for about 20 minutes, but there is something I'm missing. Do you put the bottom in first or the top in first? I looked at the other door and see how it goes, but I can't figure out how it goes into the "torque " position
    Thanks in advance
  • Larry Barickman
    Re: C3...Replacing door hinge spring
    Go to www.corvettefaq.com There is an installation article.
      • 43240
      bruce-----
      Also, when replacing the spring, note whether the "star wheel" which articulates with the spring turns freely. If it doesn't, the new spring will be short lived.
      • bruce11495
        Larry ...I went looking on that website and couldn't find the installation article. I looked in the Exterior section and couldn't find it........
        • bruce11495
          Re: C3...It's in "Interior Section" *NM*
