67 spare tire cariier bolts - NCRS Discussion Boards
  • Robert M.
    • May 31, 2000
    • 42
    What is the correct length and type of bolt for the spare tire carrier. I am using the Repro Goodyear Power cushion whitewall tire 7.75 x 15. Do they have the welded nut or the upset shoulder on the front ones? And is the length on the front 9.25" or 10.25" with the rear being either 7" or 8". Also, when the spare tire tub tray is closed, does it close tightly or is there a +/- 1" gap showing a little bit of the tire?
    Keith
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 67 spare tire cariier bolts
    this subject is covered nicely in Paragon's catalog and i believe Long Island's catalog as well. mike
    • Eugene B.
      • May 31, 1988
      • 710
      Keith,
      Mike is correct that Paragon does a good job of answering this question.
      However as a data point, I just measured the bolts on my '65. The spare is a 7.75x15 (mounted on a steel wheel) and the front bolts are approx. 9 1/8" long with an upset shoulder and lock washer. The rear bolt is 7".
      When the tire carrier is completely closed the lid fits nicely in the tub recess. No gap or portion of the tire is showing. This does raise an interesting question though. If the tire is fatter, the bolts get longer, and since the tubs are all the same depth, maybe you would see some portion of the tire? Perhaps someone more knowledgeable can comment.
      Hope this helps.
      Gene
      • Wayne K.
        • December 1, 1999
        • 1030
        Keith,
        I presently have a 215/65 Goodyear in the tub and have the longest bolts available and I can just see the tire on the lock end of the tub when I'm on my knees with my head under the car.
        • Robert M.
          • May 31, 2000
          • 42
          The paragon book lists only one for 67 and it says with gold or redline tires. What about whitewalls?
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            BW & WW are the same width...Redline is wider. *NM*
