56 Axle Seal - NCRS Discussion Boards
56 Axle Seal
+ More Options
Posts
  • Terry D.
    • May 31, 1987
    • 2698
    56 Axle Seal
    Working on a 56. rear axle bearing seal was leaking. Installed new bearings and seals, before installing axles noticed area where outside of bearing and rubber seal rides is a bit messed up. Looks like someone pounded a screwdriver inbetween bearing and flange to get bearing out. Suspect this is reason for leak. Short of replacing complete housing is there any way to seal this?
    Thanks in advance.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 56 Axle Seal
    Anything to fill holes should work. Weld and grind, epoxy and sand, maybe even RTV would work.
