Oil Filter Cannister 63 - NCRS Discussion Boards
  • Peter Ansted
    I removed the oil filter cannister on my 63 and want to be certain I am not missing any parts. A previous post stated that there is some type of spring/washer assembly inside the cannister that holds the filter element in place. All I have is the long bolt. Am I missing something here ? Thanks !
  • Larry E. Howard
    Re: Oil Filter Cannister 63
    Peter,
    Yes you are missing the spring and washer these were used in all canister type filters. Without them there is nothing to hold the element against the bypass valve. I'm not certain, but I would think that without the spring and washer you would not be filtering the oil properly or at all.
    Larry
    • Mike M.
      • May 31, 1974
      • 8396
      junk yard 56 to 67 chev pass cars and trucks with small blocks( and i think big blocks) will provide the spring and washer. mike
      • Tracy C.
        • July 31, 2003
        • 2739
        Peter,
        There should be a snap ring groove in the bolt a couple inches from the head. The spring and washer are held against the bottom of the can by a funky looking snap ring. (doesn't look to easy to remove by the way)
        If you are missing these, you may want to snag the entire canister assy if you find one at a salvage.
        These also occasionly come up for sale on eBay and typically sell around 10 bucks. Just make sure you ask the seller if it's all there. Expand your search to include other Chevy makes. (not just Corvette)
        tc
        • Craig S.
          • June 30, 1997
          • 2471
          Paragon makes nice silk screened reproductions also you may want to consider...Craig
