Re: LS5 w/C60 A/C Fan Blade question - NCRS Discussion Boards
    • 43221
    Mike-----
    GM fan blade assembly #3993889 was NOT originally used for a 1972 Corvette with 454 and A/C AND "D72" IS a date code. How can that be? Well, there was such a fan blade assembly as GM #3993889 and it was being produced for SERVICE in 1972 (and, quite awhile thereafter).
    GM #3993889 is a SERVICE replacement fan blade assembly applicable to 1970 Corvettes with 454 and A/C. It replaced the original unit used for 1970 with 454 and A/C, GM #3969926, when that part was discontinued in November, 1970.
    The GM #3993889 will have a 2-3/8" OD center hole and a 3" bolt circle for the fan clutch attaching studs.
    The GM #3992095, used for 71-73 with 454 and A/C, has a 2-5/8" OD center hole and a 3-1/4" bolt circle.
    You can use the GM #3993889 for your application, but you will also have to use a 70-style fan clutch and you will have to have a water pump hub that is dual-drilled for both fan clutch mounting bolt patterns. You likely already have the latter.
    • 43221
    Correction
    I just recalled something: you can't use the 3993889 for your application unless you also change the waterpump pulley and the water pump. You would need to use the 68-70 big block waterpump pulley (discontinued) and a 65-70 style waterpump with 5/8" pilot shaft.
    • Michael M.
      • April 1, 2002
      • 149
      Re: Correction
      Rats!! Thanks Joe for the BAD news!!! It was hard enough finding this fan blade and clutch, only to find out it won't even bolt up. These things are so very rare.
      Sincerely, thanks again
