66 brake calipers - NCRS Discussion Boards
66 brake calipers
  • John F.
    • July 31, 1999
    • 105
    66 brake calipers
    Do the bolts that join the 2 caliper halves together use lock washers?
    Re: 66 brake calipers
    John -
    Nope, no lockwashers - just lots of torque (and lube the bolts first so you don't gall the threads).
    • John F.
      • July 31, 1999
      • 105
      John, as usual, thanks for the infor.
      John
        • 43229
        John------
        One other little-known fact: 1965 and 1966 calipers, front and rear, originally used place type lockbolts to attach the caliper halves. These bolts can be identified by a bolt head with 6 radial grooves originating at the center of each flat and terminating at a hollow in the center of the bolt head. This design is NOT a headmarking; it is a design feature of these bolts which provides locking action.
        I wonder how many "100 point" 65-66 Corvettes lack this easily discernable feature?
        After 1966, with the intoduction of the 2nd design calipers, the place bolts were dropped and standard hex head, SAE grade 8 bolts were used. As John mentioned, no washers of any kind were ever used in conjunction with the bolts.
        All original bolts, place type or standard hex head, were phosphate finished.
        • Gary B.
          • February 1, 1997
          • 7027
          Joe; does anyone still sell the place type bolts? *NM*
            • 43229
            Re: Joe; does anyone still sell the place type bol
            Gary-----
            No one that I know of. GM discontinued them eons ago. This technology locking bolt is not often used anymore. The only place that I can think of that I've seen them is for certain flywheel-to-crankshaft bolt applications. Of course, these are very short bolts, so they could not be used for the brake caliper application.
            I believe that the Ford Motor Company originally developed and used the place type bolt. Perhaps, they still use them for some applications.
            • Gary G.
              • July 31, 1998
              • 51
              Place bolts
              Try this website:
              Aetna designs and manufactures heavy-duty self-locking fasteners & bolts, specifically the Aetna 6 Slop GM Type AA Bolt, for various applications. Request a quote today!
              Also, most fastener distributors such as Fastenal should be able to get them.
