72 stereo - NCRS Discussion Boards
72 stereo
  • Tony 38901
    72 stereo
    I just got the fartory stereo in my 72 working again and the reception is fine when not moving & all shounds good . Once I start driving, the radio reception goes to hell...is this normal?
    Re: 72 stereo
    This is abnormal. Additional insight(s) can be made when you give more facts about what you mean when you say radio reception 'goes to hell' when you start driving. AM band will behave differently from FM band and that can shed a lot of light. Also, if the effect happens exclusively in FM mode, is there a difference between FM mono vs. stereo reception performance? And, when reception is 'good' with the car stationary, is the stereo becon lamp on SOLID or is it flickering/blinking?
    More: When you say 'stationary' is the engine running or off. Last, when you say 'in motion' is there any noticeable difference between acceleration, particular gear, cornering vs. straight line motion and so on?
    • Mike E.
      • February 28, 1975
      • 5139
      Re: 72 stereo
      Often, if there is sharp static, it indicates that your antenna or lead are defective, and the motion of the car is causing the sharp static. (as opposed to ignition static, which is constant and low-grade irritating)
