Casting # ? - NCRS Discussion Boards
Casting # ?
  • Mike #27545
    Casting # ?
    I recently came across a big block motor with casting #3999289 and a date code of H3071. The pad was blank and the block had never been decked. Any idea what this may have come out of or if Chevrolet used this as a warranty block.
    Any help would be appreciated.
    Mike
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Casting # ?
    this block was used from 1972/78 454 2 and 4 bolt mains
      • 43242
      Re: Casting # ?
      Mike-----
      The origin of this block was likely as a SERVICE replacement bare block, fitted block, or partial engine (short block). All of these were supplied with "clean" engine pads.
      • Mike M.
        • May 31, 1974
        • 8397
        Re: Casting # ?
        agree with joe. just foir kicks, take a look mat the machined oil pan rail and see if there is stamp data there.post if there is thanks, mike
        • Mike #27545
          Re: Casting # ?
          Thanks guys. Mike, I won't be able to look at the block until later this week. I'll check for numbers then. What will these numbers be?
          Mike
