Mid year rubber fuel filler neck #3829421 is no longer available from GM. The original one was cut in two pieces some years back and needs to be replaced. It looks to be about 3"ID X 3 3/8 to 3 7/16" OD X 10 1/4" long. I found a 3" radiator hose at the local farm store which should fit but does not look like the original. Would the radiator hose work in the gas filler roll or better still, does anyone know where I can get the real thing?
Thanks: Brian
Thanks: Brian
