Seat Belt Grommet Needed! - NCRS Discussion Boards
  • Wayne P.
    • August 31, 1975
    • 1025
    Anybody know where I can find a pair of seat belt gromments for a 69? This is the part where the belt goes through the carpet. Whoever replaced the carpet left these out. I have not seen these in any vendor catalogs.
    • 43238
    Re: Seat Belt Grommet Needed!
    Wayne-----
    The seat belt grommets that you describe are a very difficult-to-locate item. These were discontinued by GM a VERY long time ago. As far as I know, they are not reproduced. So, that pretty much leaves a used source as about the only option. The problem there is that these were a plastic part and may have deteriorated due to age.
    • Chuck G.
      • May 31, 1982
      • 2034
      As Joe said, they're not reproduced, and never were. They're tough to find. You might try used parts vendors, or peruse the Corvette flea markets. You can find them for about $20.00 +/- each. They're color coded to the carpet, but buy any you can find, as they can be vinyl spray dyed to match. These grommets are HUGE....about 8 inches long....3 inches wide where they slide under the carpet. Chuck
      • Wayne P.
        • August 31, 1975
        • 1025
        I was hoping somebody might have an extra pair laying around. I've been watching the swap meets for a while. Nothing has turned up! Looks like a good item for someone to repop.
        • Chuck G.
          • May 31, 1982
          • 2034
          Problem is that it is almost a 69 only item. Don't have my JG here...maybe some late 68's used them too. Keep looking. After you find one, you'll find 3 or 4 more in rapid succession. If you call many used parts vendors about these grommets, they'll have no idea what you're talking about. Chuck
