"66" 350 HSP Intake Bolts - NCRS Discussion Boards
  • Jack Corso
    Are washers required on the 12 intake manifold bolts on a 350 HSP car?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: "66" 350 HSP Intake Bolts
    No.
    • Mike McKown
      Jack:
      I'm not sure whose requirement you are talking about but the original bolts had a "washer headed bolt" in there. Best described as a flange under the hex. I think it also was made of some alloy to avoid a "dissimilar metal" reaction but I'm not sure.
      If you don't go with the original style bolts and use regular hex head steel, I would at least use stainless washers under the bolts.
      Mike
        • 43205
        Mike-----
        Small blocks did not originally use a flanged (washer) head bolt. They should have, but they didn't. Big blocks DID use flange head bolts for the intake manifold.
        Except for folks concerned with absolute, dead-on originality, I recommend the use of flange head bolts for small block intake manifolds (especially aluminum manifolds like the 66 L-79's). Alternatively, one can use small OD, "AN" style washers under the bolt heads of standard bolts and they'll be rather inconspicuous (but not from some eagle-eyed judges determined to find this "heresy").
        "Form" is great, but "function" ALWAYS rises above it my hierarchy of things to do.
        • Mike McKown
          Joe:
          Amnesia is a terrible thing. I stand corrected on the bolts.
