1968-1982 Specifications Guide Question - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    In looking for casting numbers for a big block cast iron intake manifold, #3955287 I noticed that for 1970 this number was dedicated to an aluminum intake, and for 1971 this same casting number was used for a cast iron intake.
    Is the 1970 casting code in error or was there actually an aluminum intake with the same casting number?
    Just curious.
    Chuck
  • Robert C.
    • December 1, 1993
    • 1153
    Re: 1968-1982 Specifications Guide Question
    287s are both Cast iron. The only alum. intake for big blocks was on the 71 LS-6.,& small block LT-1s
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: That's What I Figured
      It's the ole typo deal.
      Thanks Bob,
      Chuck
        Same type of error exists in the '53-'62 Spec Guide for '62 intake manifolds - it shows the 3799349 as aluminum for '62 (incorrect) and as iron for '63 and '64 (correct). I passed the info on to Gary and Eric to note for the next printing.
          • 43221
          Bob-----
          Yes, the GM #3955287 was the cast iron big block manifold used for both 1970 and 1971 Corvettes with LS-5, as well as most other Chevrolet big block applications during that period.
          As far as the 1970 and later period goes, the only aluminum manifold used on a big block was for the LS-6. However, 4 barrel manifolds used on all 68-69 Corvette big blocks were aluminum.
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: It must be aftermarket
            Thanks for all the good info folk, too bad this master cylinder doesn't fit the mold so to speak.
            Thanks again.
            Chuck 32205
            • Chuck R.
              • April 30, 1999
              • 1434
              Re: Thanks for clearing this up for me folks! *NM*
