69 manual steering - NCRS Discussion Boards
69 manual steering
  • kelly theaker
    69 manual steering
    There is a ball and socket in the long shaft on the steering gear, the steering box pitman arm connects to. On the end is a nut with a cotter to adjust the pressure on this joint. What is the propper adjustment on the ball joint in question, . The joint it self is covered by a dust boot and thin tin cover with two bolts.
    • 43240
    Re: 69 manual steering
    Kelly------
    There is no adjustment on this joint. The nut should be torqued to 50 lb/ft, plus any additional torque necessary to insert the cotter pin.
    • Howard Nardick
      Joe,
      I have an early C-3 chassis service manual that shows the correct way to adjust the stud in a center/drag link is to bottom the monster set screw then back it out 3/4 of a turn (+ or - what ever it takes to line up the cotter pin).
      Unless I am reading the question wrong (which is entirely possible!!).
      ..Howard
        • 43240
        Howard-----
        Yes, if Kelly's question was regarding the adjustment of the ball stud in it's seats, you are absolutely correct. I interpreted his question as referring to the "adjustment" of the nut which attaches the stud to the Pitman arm. Either way, it's answered now.
          • 43240
          P.S.
          Howard----
          As I re-read the question, I see that your interpretation is the correct one of the question being asked. In fact, the question is quite clear and I don't see how I mis-read it. But, I did.
          • kelly theaker
            Re: P.S.
            thanks ,it was the ball stud adjustment on the center drag link, sorry for not knowing the terminology. bottom it out and back off 3/4 turn . try it out , does this create a stiff or high friction steering feel, or should it be very easy to rotate, no steering wheel in yet still body off . So i am moving by hand.
