C-3 Rotors - NCRS Discussion Boards
C-3 Rotors
  • John D.
    • August 31, 2001
    • 280
    C-3 Rotors
    What is the range of allowabkle thickiness for a rotor on a 1968 C-3. I have been told you can turn them once, but at what thickness are they no longer any good? Is the front thickness different than the rears? I am especially interested in the front.
    Thanks, John
  • John M.
    • January 1, 1998
    • 813
    Re: C-3 Rotors
    John, some rotors have the dimension cast on them but I believe both front and rear are 1.215" min for your car.
    • David H.
      • June 30, 2001
      • 1530
      Re: C-3 Rotors
      The same front/rear rotors are applicable for 1965-82 cars. My Chevrolet Corvette Shop Manual for my 1980 shows 1.230" as the minimum thickness AFTER refinishing.
      Replacement (discard) at 1.215". There should be a minimum thickness (wear dimension) cast into the disc itself.
      The rotor surfaces also need to be parallel and not vary in thickness over 0.0005".
        • 43221
        Re: C-3 Rotors
        John and John-----
        Yes, all 1965-82 Corvette disc brake rotors, front and rear, have a DISCARD thickness of 1.215". The NEW thickness is 1.250".
        • John D.
          • August 31, 2001
          • 280
          Thanks For the help!!! *NM*
