Fan Shroud - NCRS Discussion Boards
Fan Shroud
  • Roger S.
    • May 31, 2003
    • 262
    Fan Shroud
    My 1973 L-82 Corvette has a late July build date, trim tag date is L20. It has a fan shroud, P/N 339175, which according to the NCRS JM&TR is for a 1974. Did this 1974 component get installed on some of the late 1973 models or did a previous owner install/have install the wrong shroud at some point in time?
    Roger
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Fan Shroud
    With your build date I would not do anything with the shroud until it is seen by the team leader and his judges . Your 73 must be one of the last built and sometimes they have the next years parts.
    Lyle
    • Michael W.
      • April 1, 1997
      • 4290
      Re: Fan Shroud
      My July 3rd '73 build date car has the same shroud, as well as other '74 MY parts.
        • 43240
        Re: Fan Shroud
        Mike, Lyle and Roger----
        I believe that all later 1973 Corvettes used the 339175 fan shroud.
        • GREGG PLAPAS
          Re: Fan Shroud
          My 73 L82 has a 331869 fan shroud, is this incorrect? Is it for a 72?, as the number in my JG says it should be 331870?
          • Harmon C.
            • August 31, 1994
            • 3228
            Re: Fan Shroud
            Gregg 331869 is correct. The extension is 331870.
            Lyle
            • GREGG PLAPAS
              Re: Fan Shroud
              Thanks Lyle, Your the MAN!
