C! TIE ROD ENDS - NCRS Discussion Boards
C! TIE ROD ENDS
  • Joe D.
    • April 30, 2002
    • 382
    C! TIE ROD ENDS
    I am replacing the tie rod ends on my 61. The original ones have the grease fiting on the side. Most of the replacements seem to have the grease fitings on the bottom. Does anyone know where I can get tie rod ends with fitings on the side? Does it matter? Thanks, Joe #37862
  • William C.
    • May 31, 1975
    • 6037
    Re: C! TIE ROD ENDS
    All the original tie rods used the "side exit" grease fitting. Chevrolet serviced them early on that way, and nos or NORS examples are there if you search. It is an item covered in the Judging guide for the C-1 cars.
    Bill Clupper #618
    • Roy Braatz
      Re: C! TIE ROD ENDS
      Classic Chevy dealers have them 55 -57 Chevy are the same and many others early chevy are.
      • Dave S.
        • August 31, 1992
        • 2925
        Re: C! TIE ROD ENDS
        Joe,
        I had the same situation on my 61 with the outer tie rod ends. I found a pair of side grease fitting originals on ebay for a reasonable price. They were an NOS pair in beat up old GM boxes.
        • Christopher R.
          • March 31, 1975
          • 1599
          Re: C1 TIE ROD ENDS - Different Question
          How do you get the things off the steering arm? I know about "pickle forks." But I don't think that's going to work on mine.
          I'd like to find some kind of a puller. Any suggestions?
          • Dennis A.
            • April 30, 1999
            • 1010
            C-1 tie rod ends having the correct side grease fittings are available from most 53 - 62 suppliers. As for removal, the forks will work better than you think, If not, support the steering arm & 3rd arm with a 2x4 and one good blow will usally do the job.
            • Al C.
              • July 31, 1999
              • 274
              Chris -
              My '58 had one tie rod end that wouldn't come off even with hurculean effort. No way to get more leverage under the car. I pulled the steering arm off and took it (with tie rod dangling) to a machine shop for removal by hydraulic press. It took surprising force, finally came off with a huge POP!
              ... Al '58 #378 245hp NCRS SACC
              • Jim T.
                • March 1, 1993
                • 5351
                You can borrow a tie rod puller tool or the pickle fork design tool from Auto Zone.
