I purchased some slotted trailing arm shims ( from Quanta ) for my '67, for ease of installation and alignment. I see, however, that the holes in the one end are not round as original, but rather oval. The other end, of course, is slotted. I was wondering how these will be looked at during judging, and whether points will be deducted with reference to the "oval" shaped holes as well as the slots.
C2 TRAILING ARM SHIMS
Re: C2 TRAILING ARM SHIMS
Your 67 should use the "double hole" shims, not the slotted ones. Don't have a JM handy, but there would be a deduction for this type of shim. Chuck1963 Corvette Conv. 327/360 NCRS Top Flight
1956 Chevy Sedan. 350/4 Speed Hot Rod- Top
Although this will certainly take a minor deduction the other thing to ask is how well you will be appreciated at the alignment shop with shims that are slotted versus the holes. When I talked with the alignment shop PRIOR to rebuilding the trailing arms, they did not want to do an alignment if I had the original style shims.
Gary- Top
