C2 Tach Accuracy - NCRS Discussion Boards
C2 Tach Accuracy
  • Mark H.
    • July 31, 1998
    • 384
    C2 Tach Accuracy
    I hooked up a tachometer to the engine in my '64 a couple of weeks ago and it was several hundred RPM off from the tach in the car. Is this a common problem? Are there gears akin to speedo gears that can be changed to correct the problem?
    • 15706
    Re: C2 Tach Accuracy
    Gain error can be reduced by a competent speedometer shop by alterning the flux of the head magnet. This can be done to either a speedometer or a C2 type mechanical tachometer, but will require that you remove the cluster in
    order to remove the speedometer.
    • Mike Yager
      Mark:
      Just curious. Did the error show that the tach in the car was reading too high or too low? Certainly a low reading is worse than one that is too high. There is more potential to damage the engine.
      I may have a similar problem on my '64. I need to hook up my engine analyzer and check it out.
      • Wayne K.
        • December 1, 1999
        • 1030
        Mark,
        I'd bet that most of these mechanical tachs are off, mine included.
